Clears all VPLS counters for the specified vpls_name.
| vpls_name | Identifies the VPLS within the switch (character string) |
| all | Specifies all VPLS VPNs. |
N/A.
This command clears all VPLS counters for the specified vpls_name. If the optional all keyword is specified, all packet and byte counters for all VPLS VPNs are cleared.
This example clears all VPLS counters for the specified VPLS:
clear counters vpls myvpls
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support this feature as described in in the Switch Engine v33.1.1 Licensing Guide document.
